Discuss pir code opinion?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nelson19
hello all,
what would you code a bathroom fan that has no isolator, fed direct from light fitting?
was thinking code 4 as does not comply but still can be isolated via mcb the same way you would isolate a light fitting etc.
also had to issue a code 1 for a db with enough room along the horizontal top surface to fit a small hand in. however i have been asked to do the remiedial work and wondered how id get around this without changing the board? cables are clipped direct above the db which makes boxing difficult. any ideas?
fan with no isolator is OK if bathroom has a window. as for the board. cut a suitable piece out of plastic trunking, cut to fit snugly around the cables . glue or silicon.
I do work for a letting agent and was asked to check out a shower pump I found that the fan switchwire , neutral & earth is supplied from the lights but.............
the perminant live is fed from the power shower spur.
And yes no isolation switch either
because the isolator is there so as you can isolate the fan for maintenance , leaving the light working to see by. if there's a window, you don't need a light. (obviously the suits at the IET reckon we all knock off before dark, same as them).
hello all,
Is that a building reg though ? As in, is it in the BRB. or not.
I always thought it was a building regulation (Part something, not P). So in which case can you code it
Reply to pir code opinion?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi everyone, newly qualified spark here I went to a job earlier today where the fan was not running on after light had been turned off. Whilst...
