Discuss Plastic mounting plate for enclosure in the UK Electrical Forum area at ElectriciansForums.net
Got a couple of Quinetic WIFI switches I want to mount in an enclosure. Was going to use a galvanised steel plate then realised this wouldn't be good for the WIFI signal or switch signal. Struggling to find anything plastic. Any suggestions?
I've got a Gewiss 44206. 150x110. Was thinking about just cutting the lid off another one but seemed a bit of hassle waste of a box and I'm tight :).
Screw holes don't match on the box was going to put a plate in and screw into that
Are these boxes just PVC? Says they are "Technopolymer" but is that just advertising speak for PVC?
Might just get a sheet of PVC and screw into that
Reply to Plastic mounting plate for enclosure in the UK Electrical Forum area at ElectriciansForums.net
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I've done some work in a house, I used an existing 10mm cable on a B40 MCB to supply a 2 way consumer unit to control a heat pump and...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
I hope this is the correct thread. I have to replace the main oven selector switch in a Smeg A4-5 cooker. I can't find a proper service manual...
