C
I have 1 of those Megger clamps handy bit of kit.Had a look at clamp meters, great solution except you can only clamp individual conductors - apart from a Megger model which doesn't seem available any more. Individual conductors are only accessible in the CU, not sure if you could get the clamp in there. Splitting cables doesn't seem an easy option?
This is what you need, might find one on ebay, I still have mine.Thanks for the suggestions, some good ones there. CU might be the best bet, though space is a little limited. I also thought you needed to avoid close proximity to other conductors as that might affect the magnetic field. I'll go for the cheap clamp meter off Amazon and experiment - though as I say there's been no tripping at all so far even with the system under reasonably high load (I'm not looking forward to the bill though..)
FLEXICLAMP200 NEUTRAL | Flexiclamp 200 multicore clamp meter | 241-4007 | Welcome to RS Online - http://in.rsdelivers.com/product/neutral/flexiclamp200/flexiclamp-200-multicore-clamp-meter/2414007This is what you need, might find one on ebay, I still have mine.
http://www.biddlemegger.com/biddle-ug/Flexiclamp_200_UG.pdf
Yes they are Haverlands. I've looked them up and they are thermostatic programmable, very efficient etc etc.
. I also thought you needed to avoid close proximity to other conductors as that might affect the magnetic field. .)
Still got mine?Can't find a Flexiclamp 200 anywhere, even Ebay. I guess one might come up sometime, in the meantime I'll go for the cheapo Amazon one - thanks Taylortwocities for the advice re ohter influences
Or you can clamp the live meter tail to get total current. And then switch on one circuit at a time to see individual circuit currents.
Individual conductors available in every socket. on a ring final the same current(ish) will be at every socket.
But there’s usually room for a clamp meter in the CU, One of the line conductors going into the MCB Is the usual place. There’s usually a short loop at that point.
