Discuss Power Shower Installation in the UK Electrical Forum area at ElectriciansForums.net
Hey,
What's the standard way a power shower is installed, I've done electric showers but not power shower before.
Also is a fan mandatory in a bathroom
In order to give correct advice, where are you located? The Irish tricolour is displayed on your post,although I realise this isn't necessarily where you are.
a powwer shower is usually pump fed. the pump is a low load device which is usually connected to a local socket circuit via a FCU with 5A fuse.
I'm in the UK, although the regs are pretty similar anyway
There are a number of differences around bathrooms, and the legalities are very different.
But for a power shower you could either run a dedicated circuit, or spur off a socket circuit, or even feed it from a lighting circuit. Make sure it's RCD protected, and if other circuits in the bathroom aren't then supplementary bonding will be needed too. Fan will come under Building Regulations rather than Wiring Regulations, but I think the general advice is that if you have a window then it could technically be omitted.
Reply to Power Shower Installation in the UK Electrical Forum area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
Hi, after a bit of advice. Have tried a lot of plumbing and electrical shops but no one seems able to help. I have an Isolator/PSU 230v/12v. It is...
