sythai
1,695
420
101,758
Devon, United Kingdom
Hi chaps....
Just seeing what any of you chaps that price by point would charge per cat6 point ? (This would be first fix only - someone else making off and supplying front plates)
x 13 of them, longest run 25m. (Normally charge around £50'ish 13a socket.) This is only part of a job which also includes power and lighting, which I've already priced per point.
Thanks Sy
If you are just running the cables under the floor £260.00 ( that woul inc patching both ends so I would say £150.00 but all depends on runs
so £20/point if you patched both ends.... £11.50/point just to run cable to each point.... seems a bit on the cheap side.
Fair enough mate........... was going to try for £25/point, should cover me for a box of cat6 and my labour then with a bit of profit on top.
Are you testing and certificating? I would be looking around £500 for that with patching in and testing, if you're only dropping the cables in then you'd have to be cheap as that's not even half of the job - just cover your time at whatever rate you work for
sythai
Pricing.....
Business Related
Thread Tags
sythai,
sythai,
