Discuss Problem Solved in the Australia area at ElectriciansForums.net
A
acat
If the thread has gone past the point of being re taped, I usually get a plaster depth 16mm galv back box take one of the oval knock outs drill through either end with a 4mm bit, bend the knackered lug flush with the box, drill two 3mm holes in the back of the box that correspond with the two on the knock out, tap them screw the knock out to the back of the box with shortened 3.5 screws, in line with where the faceplate screw falls normally then drill a third hole in the centre of the knock out thread it, then use a 75mm 3.5 screw as normal. hope that makes slight sense.
The above was posted by Pennywise on another thread and no doubt it is a problem that has bugged us all at some stage. This got me thinking what other problems have we come across and what was your solution to it.
So lets have the problems and solutions and if you can think of a better solution please post it.
Chris
Yes , back of lug is better due to long metal tab that comes with some lugs,( although once superglue is set I find it can easily take the pull of the screw)
Still, quicker than drilling.
http://www.electriciansforums.net/e...l-forum/16759-2-way-lighting-help-please.html
First thing you need to do is find out which cable is for the hallway lights (if you haven't already).
On one of the cables join the live and neutral wires together and test for continuity between live/sw. live and neutral at hallway light. If you don't get a reading try same thing on other cable.
As the hallway is only 1way the neutral wire will likely be your switch wire and should be identified with brown sleeve. You can connect that to one of the gangs in the switch. Brown to Common, Blue (with brown marker) to L1.
If the other cable is also T&E, I would think that it is probably wired as Notsosmart's diagram suggests probably using the live and neutral wires as strappers and the light getting it's neutral from elsewhere. Take a look at how the upstairs switch is wired. If you have brown and blue wires going to L1 and L2 then I would say this is the case. If so, in the downstairs switch you will need a link from the common of the hallway switch to the common of the landing switch, then brown and blue(marked brown again) into L1 and L2 of landing switch.
Something like this:
Even simpler way shown to me by time served sparks. Drill through knackered lug (to ensure correct location) and through the back of the metal box. Tap new hole and use 50-75mm screw. Only one drill and tap.
On rewires, if you can pull the old 1.5mm T&E switch live returns out from above, you can avoid chasing out by pulling 1.0mm replacements. Pulls through nice and easy.
I done a job recently and saved oodles of chasing by pulling EVERY SLR like this.
And dont worry about mixing 1.0 with 1.5, the live return will only ever take the load of that single lighting point (unless you are linking).
SPARKYA will you please stop hijacking threads with this question. I have counted five posts with this question in already. You have your main question in the forums and have replies to it, please stop abusing other's posts. Thanks.
Thanks Rocker now removed.
or---------------------- leave it for the plasterer. it never fall off once he's gobbed half a hundredweight in and around it
Reply to Problem Solved in the Australia area at ElectriciansForums.net
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
You might remember this delight from the dodgy trade pictures thread.... I finally got back to quote for sorting today. The chicken and egg...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
New construction in USA. I think that the builder put ceiling fan rated boxes in the ceiling. But when I remove the cover, I see a strange box...
4K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
