Discuss Problem with downlight in the UK Electrical Forum area at ElectriciansForums.net
I have actually had the same problem with LAP I really don't think they are good quality what else could be causing it
I'm regretting buying lap the metal clips don't even hols in the fitting properly and seriously thinking of ripping them out and throwing them at the man at the screwfix desk. Plus the plastic housing at the back which holds the terminals in are cheap plastic
I have dimmable lap downlights I'm qualified and even I have flickering. Tried adjusting the potentiometer screw at the back of each gang aswell.
Even got this trailing edge dimmer
Retrotouch Trailing Edge Push Rotary LED Dimmer Switch 3G 1 / 2 W 600W Glass White / Chrome
Not buying lap again
Lap should be renamed Crap
Reply to Problem with downlight in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
