Discuss Proximity of ditra heat thermostat to tub in the DIY Electrical Advice area at ElectriciansForums.net
jheyerman
I am nearing completion of my bathroom which included installation of ditra heat. The bathroom is quite small and the thermostat (a touch screen version - Schluter®-DITRA-HEAT-E-RT | Floor Warming | schluter.com - https://www.schluter.com/schluter-us/en_US/Floor-Warming/Schluter%C2%AE-DITRA-HEAT-E-RT/p/DITRA_HEAT-E-RT) is located on the same wall as the long side of the alcove tub approx 13" away from the start of the tub. In the rough-in inspection, the inspector had no issue with the location. I had always planned to install a piece of glass at the tub giving me the ~39" of separation. However I am not going to get that done before the permit expires. The rule 62-130 is that a '"manually operated control for a heating deevice" may not be placed within 1 m from a sink... etc'. So my question is, is the ditra controller a "manually operated control"? The screen unit of the control attaches to the relay device that is located in the electrical box and a four in contact connector passes only low voltage to the screen. Therefore I do not see the risk since a person in the bath cannot interact with high voltage. Thoughts?
Thanks!
Jeff
Thanks,
Jeff
Thanks!
Jeff
Thanks,
Jeff
Jeff I don’t care what it is give the inspector what the inspector ask for. I’m assuming you have talked and some of them will work with you and some won’t good luck
Reply to Proximity of ditra heat thermostat to tub in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone We have a little problem with a heating system on one of the projects (quite big house in south Kensington) and we are looking for...
Hi All; I have a flat with 6 areas warmed via underfloor heating. Each of the areas are controlled by its own thermostat Microline Ultra-Thin...
5K
I was just reading the Building regs (as you do when you are a very sad person:drunk:) and there is a difference in the definition of special...
Geoffsd
G
