Discuss Questions about RCD's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
horsey89
Helllo all,
Just a question about the operation of RCD's
At work there is 8 containers all fed from a panel. Each container is assigned a 132A RCD from this panel. The feeder units in each container have RCD's for lights, sockets & heaters ect. When I was fitting some new sockets into one of the containers I turned off the RCD for sockets in the feeder unit rather than turning the whole feeder unit off. This was to cause as little disruption to the workers in the cabin. When I cut through the neutral for the new socket it tripped the main breaker for the feeder unit and the main breaker that feeds all 8 containers.
Is this what should be happening? Do I have to isolate the feeder unit for a whole container to work on anything in it?
Also there are other containers which are fuses rather than RCD's, Would I have to isolate the whole container or can I just pull the fuse for the heaters and allow the workers to still use the sockets while I am terminating a neutral.
Any input appreciated
cheers
Sounds like a temporary sweat shop to me.
Firstly, How many phases are there feeding these containers?
Secondly, 132A RCD? What is its leakage allowance?
Thirdly, Safe Isolation ?
Fourthly, I assume you are disconnecting both phase and neutral when making new terminations
Sounds like you dont have any discrimination between any of the RCD's in circuit.
As requested, can you clarify the mA rating of each of these RCD's??
I feel you maybe out of your depth here mate. You should be carrying out safe isolation, even if the isolation is only local especially if you are considering the possibility of people working in the vicinity of the electrical work.
I am not questioning your skills or ability as an Electrician, but some of the things you ask have sounded alarm bells, and i fear that you may not have enough relevant experience and knowledge to be able to work safely in the environment that you describe.
Cheers............Howard
When you say Rcd for sockets do you mean single mod rcbo??
As if it is then yes it will trip the other end as there single pole. So neutral to earth will still be detected at the other end.
Reply to Questions about RCD's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
