Discuss Quinetic buzz noise in the DIY Electrical Advice area at ElectriciansForums.net
Rambo6
Hi everyone! I'm new here but I am seeking professional advice on what to do. Installed wall lights in two rooms using Quinetic switches system on both. But there is a buzzing coming only from these 2 rooms. I assume it is from the quinetic receiver (installed in loft) or the lights itself. Is this common? Are there any solutions? Please advise.
Many thanks for your kind help.
TL;DR
Quinetic buzzing noise, how to solve?
Have you tried replacing the lights to rule them out? Replaceable bulbs?
normally buzzing is coming from a transformer in a light fitting, but I suppose the electronics in the receiver might be the culprit also. Do you hear it in the attic?
Many thanks for your quick reply.
I have tried different bulbs and the noise still there. In fact, I turned off all electricity in the house (via main switch board) and the noise is still there!!!
No noise from attic..
You turned off all the electric, and the buzz is still there????
wasps?
seriously though, if you turned everything off, then it can’t be anything you have got that’s making the noise.
Reactions: DPG
Reply to Quinetic buzz noise in the DIY Electrical Advice area at ElectriciansForums.net
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
