B
beameup
Just after a bit of advice regarding the following. First up I am not electrically qualified and know limits of what I would and would not attempt but am electrically read.
The situation is that I have a radial power circuit fed from the consumer board and protected by a 32amp RCB feeding 5 sockets on the ground floor in living areas. The kitchen and appliances are served by a separate radial and a dedicated radial for the oven.
It is in good condition and the existing radial arrangement is wired in 6mm cable (mostly; see below).
I need to add a double socket into this arrangement close to a telephone point to enable use of a router and lamp at the end of a hallway which is around 4 metres away from the circuit.
Currently the first leg of the radial exits the consumer board and enters a junction box (JB1) from which a single socket has been fed as a spur (this is in 2.5mm cable I presume this was an later addition. I understand this is allowable under reg in 2.5mm from a 4mm or 6mm 32amp radial providing it is a SINGLE double spur due to overload protection at the socket end, maximum of 26amps being drawn).
The main radial then continues to a double wall socket in the rear room and onward to a further junction box (JB2) which then radiates out to serve three separate sockets in a parallel arrangement. See image for a better idea:
The planned additional twin socket is shown. What are my options for adding this in to the current arrangement?
1. Can this be an extension of the existing junction box spur (JB1). If so, I would plan to replace the 2.5mm cable here with a higher rated cable to avoid the issue of potential overloading with a 32amp RCB or derate the whole system to 20amp.
2. Alternatively could the planned double be taken directly from the existing junction box thus creating two separate spurs off this point in the circuit as below? Which is the better arrangement?
Having calculated the voltage drop I understand 4mm cable will be suitable but would this create any issues with the existing 6mm wired system? Am I better just harmonising to 6mm throughout any wiring extension or spur? Having done this sort of this before I know this can create issues with cable crowding at the points of connection.
Any help from an experienced sparky is much appreciated!
