H
Discuss rate my fuse box (or consumer unit to be politically correct!) in the UK Electrical Forum area at ElectriciansForums.net
The original fuseboards were in the cupboard beside the meter as in the picture. The cables ran behind the bit above which was already boxed in with plywood. All I did was move the new consumer unit up and replaced the plywood. I upgraded the tails to 25mm and took them up to the new position. Do you think I should have an upfront 100mA rcd?
What if the meter tails are more than 50mm from the surface? I did a job once, where I ran the meter tails surface in maxi trunking, in the corner of a wall below the CU. Went back a few months later and the customer had boxed in the trunking!No point fitting a 100mA RCD - it wouldn't comply, as it needs to be 30mA for shock protection.
I like your approach, looks neat, but as I said, you could come unstuck if you put it up for assessment.
Personally, I would consider it to be no different to running the tails in trunking, but that's just my opinion. Yours is wider, and made of plywood, but it's doing the same job.
all twin and earth cables should min of 2mm of the outta sheath withing the fuseboard. this guy has stripped his cables back to far.
code 2
Because Dave Joe public is not that smart!
Remove the cable ties from that bundle of neutrals and in future use something other than a machete to remove the sheath from the tails. Actually not bad at all.
Given it's hi integrity CU I would have left spaces next to the main switch
why Murdoch?
The sheath enters the fuse box more than 2mm. But hard to tell from the pics. What regulation is that by the way?
Slightly tongue in cheek, as it's a decent job. OTOH if you present tidy work and ask for critique, it will be judged to very high standards. I'm not looking for gross errors and don't expect there are any, I'm looking for finesse. I'd have used a Rotax stripper and the sheath would be very neat indeed.
Reply to rate my fuse box (or consumer unit to be politically correct!) in the UK Electrical Forum area at ElectriciansForums.net
