Discuss RCD tripping on lighting circuit when lamps (bulbs) are put into light fittings in the UK Electrical Forum area at ElectriciansForums.net
H
heartofgold
Hi,
Lighting circuit trips the RCD.
took out all the lamps and it holds. Put any lamp back into any light on the circuit and it trips. All but one of the light fittings on the circuit are Class 1.
Any advice gratefully received
hog
Are you an electrician? Has there been any alterations recently?
Sounds like a neutral problem to me.
Yes I'm a spark. Yes the property owner fitted new accessories! Told me there was a problem with the tw way switch on the landing/hall before I started.
Going back this afternoon and I'll take all the lights down first and work back from there
try starting at the switches...
- - - Updated - - -
Oh yes, but the DIY forum helps a lot here, some of it goes there first now lol
well alls i can say mike is this `net` has a bloody big rip in it...
Hi,
hog
I am interested in the thought process which led to you taking all the lamps out when faced with an RCD that wont hold. I have to admit that in the hundreds of instances I've been faced with this problem over the years not once have I thought to myself...."I know,I'll whip all the lamps out"
when will customers realise that it's £40 to fix the light, £60 if he watches, and £80 if he's messed with it first.
dont waste your time here Wire...
its like talking to an apple or summat..
Many, many, many moons ago, when I was a programmer, when my boss came along and looked over my shoulder I'd just stop working and gaze around for a while until he bogged off.
He soon learnt not to hassle a genius at work.
its the cold shoulder tecnique..
i have had to employ this method of getting people i dont like to
f%*k off on several different occasions
Reply to RCD tripping on lighting circuit when lamps (bulbs) are put into light fittings in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
