Discuss RELAYS - Latch V Momentary types in the Auto Electrician Forum area at ElectriciansForums.net
Hey guys.
As the BT switch delivers 4 x 30A - could I have to of them wired together to push 60A to the main controller?
Is that safe? What's the best way to physically wire that together?
Then I could lose a relay and simplify it further. Or is a relay preferable?
See pic:
Problem is if one fails, which is uncommon but can happen ...the one poor relay gets the full load, not good....get the right size relay and if it does fail, it fails safe.
Hi guys.
What does it mean when a device must 'drain to +12v' ???
i have a switch that has 3 terminals. The manufacturer says 1 is earth, 1 is direct to battery +12v and 1 drains to +12v
Any help appreciated.
Reply to RELAYS - Latch V Momentary types in the Auto Electrician Forum area at ElectriciansForums.net
S
Thought I’d write a little on changing from being a UK spark to a NZ spark, after seeing the Australian thread. Kiwi licencing is ran by the...
7K
SparkyJoe
S
L
Hi Guys, I am planning to install a kill switch on my car on the starter however I am not very good with electronics and ... , I have done an...
4K
linux44
L
