Discuss Removing pull cord switch. in the Lighting Forum area at ElectriciansForums.net
Quick answer is no they cannot be linked together in a junction box.Pull cord switch is no longer used in bathroom, lighting switched on/off by external (to bathroom) fused switch.
Would like to remove pull cord switch, can the cable be removed and the previously switched terminals be linked together in the junction box?
Thank you
WET PANTS BEEN DOING LECTRICS AGAINand why is a cpc used as as witched L?..... bodge alert.
Reply to Removing pull cord switch. in the Lighting Forum area at ElectriciansForums.net
