J
jimboallen
Hi All.
I have another question for you. I suppose its really a 'is it legal to' question as its a business setup providing power to customers via 16amp sockets.
Please refer to the picture attached, at the moment, 3 phase comes in on the right, into a 3 phase RCD, then the 3 phase goes off into its own MCB. A single phase is taken off the top of the 3phase RCD and feeds a single phase RCD, then into 4 single phase MCBs and then down to the sockets.
My question is, would I be able to and would it be OK to do away with the single phase RCD. To do this I would like to take a single phase off the bottom of the 3 phase RCD and go straight into the 4 single phase MCB's.
The reason for this is we need more space in each box to fit meters. each meter is the size of a single phase RCD and we need to fit 4 on the rail.
Obviously we would ensure the 3 phase RCD was the same amperage as that of the single phase one and we understand that if any single socket trips the RCD we would loose the 3 phase socket (fitted just out of view on the bottom right).
Is there any logical or regulatory reason why we cant do this?
Thanks in advance
James
Thanks in advance
James
