Discuss Replacement shower cable in the UK Electrical Forum area at ElectriciansForums.net
Just done 80% rewire in house where 12m of 6mm t/e shower cable replaced with 10mm t/e to allow upgrade of shower which has already been done prior.
However, due to other extensive work in house it was simple to replace all cable from consumer unit to shower pull switch but the cable from pull switch to shower unit is approx 1m down a newly tiled stud wall and is still coppper 6mm t/e.
Question is - will that 1m of 6mm t/e still mean shower can only be upto 7.6kw if wall insulated and 8.7kw if not insulated.
In theory the entire circuit should be rated for the 6mm section, on the other hand the regs have a get-out clause for cable calcs along the lines of "dependent on the electricians judgement and experience", so if your load is only slightly over what the 6mm can "officially" take, you might "get away with it". Judgement call on your (or another electrician's) part!
32A MCB if 6mm is in insulated wall. 40A if ref. method C. 8.5kW will be fine.
can be fitted with the aid of.............
I've used a Bosch PMF180E with the diamond blade to remove the grout between the tiles, pulled them off and replace with new after needing to do a similar job. But I had spare matching tiles to hand. Might be an option if the 6mm really won't do.
Reply to Replacement shower cable in the UK Electrical Forum area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hey all, Ive been in and out of a huge house rewiring as the renovate it for a year of so. Every is thing done and dusted except the downstairs...
Hi, Same project as detailed in my other post (I want to run shower cables to the CU whilst the kitchen ceiling is disturbed). I'm going to...
Hi All, Im quoting to install an EV charger (Dont worry - fully registered, but only been 2 weeks so i'm still picking bits up). Consumer unit...
