Discuss Replacement strain relief clamp strip for large junction box in the UK Electrical Forum area at ElectriciansForums.net
I am doing some rewiring within the large junction box used for my central heating and hot water controls, which requires me to make use of two additional cable entry points. Unfortunately, many years ago the original installer threw away the flexible brown strips that were used as strain relief (ref attached photo).
Can anyone suggest what might be a suitable material for replacing these missing strain relief strips?
The usual thing I use is the strain relief clamp from a 13A plugtop or fused connection unit, or even one from a new heating junction box, if I can find one the right size. FCUs are often fitted with out a flexible cable coming from them, and the heating junction boxes have more than required, so they're effectively free.
The brown fibre ones in your pic have largely been superseded by plastic versions.
As I had nothing suitable to hand this afternoon, I rearranged my cables and found a way to handle them all with the existing strain relief.
However, thanks for those comments and suggestions. The cheap cord grip with the expensive postage would unfortunately have been too narrow.
You could also fix them with p clips screwed into the wall right where they exit the junction box.
Reply to Replacement strain relief clamp strip for large junction box in the UK Electrical Forum area at ElectriciansForums.net
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
Have been given the job of changing a bank of office light fittings over to shiny new class 2 jobs. Lights are wired 3 plate from a junction box...
Guest123
G
I have recently removed a single fluorescent tube fitting for a customer who wants it replaced with a Class I circular 3-spot unit in a back room...
7K
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
