Discuss Reposition water service earth bond. in the Electricians' Talk area at ElectriciansForums.net
if the stopcock is otherwise OK, apart from not closing, why not leave it in and fit a second one after it? sounds a much simpler job and the bonding can stay as is.
Yes that's what the plumber has done. It's all copper from the old stopcock to the new one so bonding will be ok to leave.
Do they intend to use plastic pipework or plastic stopcock or will it all be copper and brass? If plastic you may need to reassess what items in the bathrooms require bonding.
Where's Cockburn when you need him? ;)
Copper. Just going to leave current one in.
Could you move the bonding cable to where the new isolator is going to be?
Would have to be rewired.
So this seized open stopcock is going to be abandoned and a new one fitted a bit further downstream??
There's nothing wrong with that and I've done it myself. Why not just leave your bond where it is and if anybody wants to argue the ---- tell them that one is the main stopcock and the one under the sink is a secondary one.
Looks like this shall be the plan.
Thanks for your help folks.
The regulations state that MEB connection to water service shall be made as near as practicable to the point of entry.
There is NO mention of stopcocks.
It is very simple.
never heard of it.though dysentry was a US soap with that slapper collins.
Reply to Reposition water service earth bond. in the Electricians' Talk area at ElectriciansForums.net
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Did a eicr on a upstairs flat, there is 1 main bonding cable from the consumer unit, the gas pipe comes from the gas meter outside and up the wall...
