Discuss Request for advice on connecting UV lamps to the ballast. in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a fairly simple question like in the title of the post.
How to connect Two 9 watt UV lamps to a ballast probably electronic. I suppose electronic will be the best in my case, due to the built-in starter. I have read various sources of information but did not find my specific case.
I would ask for the simplest explanation step by step, because my knowledge of electrics is very flimsy. All advice is very welcome, because I don't know what to do anymore.
Thank you in advance for your answers and your time.
The ballast must be suited to the type and number of tubes. With an electronic ballast the AC power is usually connected straight to the ballast, then there are various connections to the tube pins that will be shown schematically on the unit itself. As you say this is the simplest to configure and an electronic ballast gets the greatest life and efficiency out of the tubes.
Reply to Request for advice on connecting UV lamps to the ballast. in the UK Electrical Forum area at ElectriciansForums.net
Hi: I am the custodian at Peru Public Library, Peru IL. About 20 years ago, I installed about 150 new General Electric brand electronic ballasts...
Hello gents I'm just after some clarification, I have a kitchen light fitting that uses a 2D 28W compact fluoresent lamp that I'd like to...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Every three weeks I get to hang around the Royal Free Hospital between blood tests, physical exam, scans etc that take a few hours of separate...
