M
mmcg
Hi all
I have 2 quick questions regarding domestic ring main socket circuit calculations im hoping i could get help with.
1) regards calculating I[SUB]t[/SUB]from table 4D5 in the regs it states that in order to use 2.5mm conductors that it should have a max value of 27A (ref method C), im unsure how to get this figure as I[SUB]n[/SUB] is going to be 30 or 32A. The only correction factor applicable is Ca which in this case is 0,94 so as i understand it i[SUB]t[/SUB]=i[SUB]n[/SUB]/correction factors =30/0.94 =31.9A. Obviously i understand it is common practice to 2.5mm cable, im just wondering how to prove this on paper.
2) regards volt drop in a ring main, i have heard conflicting theories about how to calculate this so was just wondering how other people would go about this?
Any help is very much appreciated
