Discuss Robin 4112 Phase Earth Loop Tester in the Electrical Tools and Products area at ElectriciansForums.net
Is it definitely a 4112, as that's rather old?
Looking at the 4113, a manual is hardly needed, it's self explanatory if you've used any type of tester before.
I doubt it'll have D.lok so won't be any good where RCDs are fitted.
Here's the manual for a 4116, courtesy Marvo 2013,
https://www.electriciansforums.co.u...116-4118-4120dl-instruction-manual-pdf.18667/
Hiya Buzz - yeah... old like me! I'm 69 now and been retired - or should I say semi-retired - since 2004. Trouble is you still carrying on working, just for somebody else! My Robin is a 4112, and is probably as old as I am. It looks a bit like the piccy above but it's analogue which will tell you how old it is.
Thank you for the link. Very much obliged. I'll nip over and download it now. :0)
Reply to Robin 4112 Phase Earth Loop Tester in the Electrical Tools and Products area at ElectriciansForums.net
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Would a small UPS, running on batteries, be a suitably stable 230v 50hz supply while I do some tinkering with the loop calibration settings on an...
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
