L
leighman
Hello
I had problem at work on a Caravan/camp site where I installed a distribution box for the caravans parked on the site. The same circuit on the Camp site had the need for a replacement of a length of cable between a single phase isolator and a junction box (because it was incorrectly sized.) So I went on to safely isolate the installation and perform the necessarie work: I then switched on the distribution circuit isolator. The Current using equipment had not been disconnected or isolated from the DB during the time that I performed the works. The only means of isolation had been the 100A main single phase breaker.
I was then told that allegedly the act of not disconnecting the current using equipment before replying the current via the Main isolator had caused the switching current to Damage the current using equipment
Just wanted to know how Electricians on this Forum would react to this situation and what regulation you could quote from to either prove or disprove a stance you may have on this issue??
