Discuss Shower light on and Switch light on when shower pull cord is off in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
sparky1966
Hi everyone,
I was wondering if someone could help me please. I have recently looked at a shower unit in a house and when you pulled the on/off cord to the on position everything was fine but when you pulled it to the off position the light on the pull cord switch stayed on slightly and the light on the shower flicked very lightly. The switch on/off indicator did show off though.
Does this mean there is a loose wire somewhere or could there be any other problem? I did look under the cover of the switch and there were all the correct wires there. I have not been able to do further investigations.
I hope someone can help.
There are a few reasons for this a faulty switch were the contacts on the switch are stuck on , switched bridged out on one of the conductors ,or an incorrect polarity where the Live and neutral are reversed , this circuit should be checked out by a regestered quallified spark as soon as possible
pullcord isn't rated at 40Amp with shower rated higher is it. had this myself before and swapped switch for correct rating, tested circuit and everything was fine from then on. guess insides of pullcord had started burning out. obviously make sure cable size + mcb etc are all correct as well
also check that some numpty hasn't covered the cables leaving the pullcord housing with insulation, asthey may have started burning out together and be bypassing the isolator.
As above it sounds like a faulty switch. Do a continuity test from the supply side to the load side of the switch and turn on and off.
Is it an MK pull switch by anychance? if so I have found they are not as reliable as they used to be, its difficult to terminate inside them. the supply cable puts pressure on the terminal which over time makes the rocker pull switch inside wear unevenly causing the problems you are getting before eventuall failure of the switch.
Get a crabtree pull swittch as termination without strain is simple due to a different design.
HTH
Ben
think from october 2011 he's either fixed it by now or the house has burnt down.
Reply to Shower light on and Switch light on when shower pull cord is off in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone My mira power electric shower is not doing anything when i press the power button. There is no led lights to check on the unit to...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
