Discuss Sidecutters or Shears ? in the Electrical Tools and Products area at ElectriciansForums.net
L
Lofty
So which is best ? I'm old school and have used sidecutters for years but they're getting past it and I want to replace but what with. Should I go with cable shears such as the CK T3963 or the CK Combicutter3 sidecutters which have 1.5 and 2.5 'notches' in the blades.
Who's using what and why ?.
Regards, Lofty.
I use sidecutters but my apprentice just bought CK combicutters and they are really quite good. Thinking of investing in some myself.
ive taken a quick look at the combicutters it reminds of times when i've tried to use sidecutters with a hole blown in them .there are times when you need sidecutters and times when you need strippers this tool won't replace either or both
Hi, The C.K combi-cutters 3 are great side cutters, as i use then quite a lot. They really are worth their money, on the downside the did become blunt fairly quickly which i am only dissapointed. I also have the c.k. cable shears,and also a good tool to use as it makes cutting 6mm cable or so very easy, it only takes 2 fingers to cut through 6mm. Anyway from my point of view, it is handy to have both sets.
Reply to Sidecutters or Shears ? in the Electrical Tools and Products area at ElectriciansForums.net
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
So what are your thoughts? Over 100 schools in England closed, 40 or so in Scotland after a building material with a projected lifespan of 30-40...
