H
horsleya
I am hoping to use my own house for my assessment to join either NICEIC/Elecs/NAPIT however I have a question over the size of the earth conductor.
Most people give me the stock answer of 16mm as the Tails are 25mm however I do not believe that this has to apply to a TT system although I am happy to be proven wrong.
542.3.1 refers to 543 which in turn states that I can calculate the CSA based on the adiabatic equation in 543.1.3. I am no expert on this equation so I would love to see someone work this through or let me know what they believe the values should be.
I have a Ze reading of 36 Ohms however when the Main Potential Bonding is connected my Zs drops to 26 Ohms (Parallel Paths). Therefore my PFC is 9amps and this checks out with my tester (I have rounded the figure up for this message).
As I currently have a 10mm cable about 3M long going to the Earth rod I believe that this is OK. The cable is above ground and although currently exposed I intend to enclose it in plastic conduit.
Am I missing something?
What should value t be in the equation? Should it be 0.2 from table 41.1 on page 46?
