Discuss Smoke Alarm minimum dBA in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
BS5839 as summarised by ttsfire.co.uk states:
Alarm Sound Levels
It is essential that, whenever any of the smoke alarms in the dwelling detects a fire, the sound level of the alarm (from either that smoke alarm or other smoke alarms interconnected with it) is sufficient to wake up at least the adult members of the household. The sound level in any bedroom is likely to be satisfactory if there is a smoke alarm in the bedroom, interconnected to all other smoke alarms in the dwelling. However, if this is not the case, the nearest interconnected smoke alarm to the bedroom, capable of sounding an alarm whenever fire is detected anywhere in the dwelling, should not be further than 3 m from the bedroom door.
In some dwellings, such as flats, maisonettes and houses in multiple occupation, doors to rooms may be fire doors, which tend to attenuate the sound from smoke alarms more than normal, domestic doors. In these cases, great care should be taken to ensure that the sound level in bedrooms is sufficient. In some houses in multiple occupation, the local authority may demand that the sound level at the bedheads in some or all bedrooms is 75dB(A) when the bedroom doors are closed. This should be determined before finalising the number of smoke alarms required, because 75dB(A) is unlikely to be produced at the bedhead unless there is a smoke alarm within the bedroom.
If occupants suffer from severe hearing impairment, BS 5839 : Part 6 recommends that special alarm devices, such as high intensity beacons and vibrating pillow or mattress pads, be provided.
Reply to Smoke Alarm minimum dBA in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
