C
chloebear
Hi all,
I have a bit of a strange requirement for a client of mine - they have a pump room for their pool circulation equipment and the main pump is on all the time. this pump has a 'built in' thermo-cutout and in the event of a fault with the pump causing overheating it 'should' automatically cut-out and cease to work (in theory) however, my client has already had one of these pumps burst into flames and is now a little concerned that the new pump's cut-out will not function as it should.
I have been asked to fit somekind of smoke/heat alarm in the pump room that will, when it senses heat or smoke, sound the alarm to all other interlinked smokes and also cut the power to the circuit that the pump is on.
any good ideas?????????
