Discuss socket in a bathroom... yes.... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mr smith
advice on this one , lads.
very small appartment.
under the sink in the bathroom is a washing machine.
like i said very small appartment.
in the cupboard next to it (all very neat and tidy) is the socket for it.
18th edition board in the lounge but the socket is within 3 mtrs of zone 1 , albeit buried deep in the recess of the cupboard.
thoughts , shouts and reasons of disbelief , all welcome....
i'm thinking I could make it a fixed appliance and spur off then make the socket a weatherproof box.
never met this before... stumped....
Put a lock on the cupboard then it is only accessible with a key or tool.
If you are not working on the installation, sounds like it's probably less likely to be used for portable appliances in the bath area than a socket just outside the room would be. On that basis you could put it as a deviation as it would be at least as safe as a compliant installation (assuming no water dripping/condensation issues).
If you are working on the installation just chop the plug off the washer and replace the socket with an FCU assuming its >600mm from the bath.
Doors (if the cupboard has a door, but without a door it would be an alcove) limit the extent of a room containing a bath or shower so the socket is not in the bathroom but in a small area off the bathroom, a bit like having a socket on the wall just outside the bathroom door.
and that is waaaay beyond my understanding of both the building code and also the regs , but a great answer. cheers
I am just pushing at the limits of what may be assumed, 701.32.1 specifies that the location can be effectively limited by walls, doors and windows.
Whether this can be applied to a cupboard door is debatable.:)
As this example clearly shows, not only should you put the sockets above the sink, but install the light switch at a slightly different level to give a rustic look
Reply to socket in a bathroom... yes.... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
  • Locked
5K
Hi All, Need advise on something. I have seen a diagrem somewhere showing that we cant have any electrical socket near the washbasin/tub etc...
4K
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Yes, it's another EICR coding question - hurrah! :blush: Inspecting a small 1 bed 70s ex-council flat that was going well. Main Bonding had...
7K
