Discuss Socket outlets with built in USB in the UK Electrical Forum area at ElectriciansForums.net
Andy-1960
Not a great fan of these for the reasons mentioned in the video, but what this guy highlights regarding the earth is more than a bit worrying. The video goes on a bit but just a warning that these things are on the market!
I have always been wary of these. The first wave were no-brand garbage that I wouldn't touch with a barge pole. This article from 2014 also persuaded me to steer clear....
http://www.electricalsafetyfirst.org.uk/mediafile/100145109/web_usb-article-from-so32.pdf
Now the bigger brands have taken these into their ranges I am a bit less worried. I have fitted the BG and Schneider Lisse versions and they seem to be well made.
My chosen brand for second fix gear, Hager, still have not brought one out, although apparently one is one the way.
I don't see the problem? Socket with a transformer in them? Obviously when with larger brands like bg etc
Wouldn't know about when testing as I don't do testing(me personally. Boss man does it before everyone jumps on me thinking I don't test at all)
I think you still have a lot to learn If you don't see the problem!
I found the same sockets on amazon with these fantastic wiring instructions.
They're a pain imo. Even the reputable branded ones. I try to talk people out of them if possible.
They solve a problem that doesn't exist imo.
How? They're like any other socket?
Never have enough usb plugs in my room so installed one next to my bed for charging my ps4 pad and all my other gadgets
Not having a go but imo they're like any other socket just a little thinker for the transformer
Some brands don't fit in 25mm deep boxes. Have had a failures on Click, MK and BG USB sockets meaning a re-visit. They make IR testing more time consuming.
Probably would still prefer to plug my gadgets into the proper manufacturer approved charger to be honest.
Saw some in Screwfix the other day under £7 each. Looked ok. But as USB C is the next connectivity option fitting the old style USB means they will be out of date in a few years.
A customer got some BG ones and I was pleased to see that they stated they could be IR tested at 500V and give a minimum reading of 10Mohms, I got 59Mohms with three in the circuit.
I don't generally fit them but will if requested. I am no longer worried about the manufacturing quality for the main brands, but it is another thing to go wrong.
Sounds like they've got a suitably rated capacitor in series with the supply to the USB power supply. So it'll block a DC test voltage but allow the small AC current for the charger.
They're all the same input for phones, controllers and other little bits; 2A at 5v(if my memory serves me well). The only ones that differ are tablets and fast charging phones (fast charging being optional)
Nothing wrong with a socket fitted with a USB just don't fit cheap and nasty rubbish from Amazon, I suppose those who are against them don't like the sound of those new fangled mobile phone things also!:)
They are not like every other socket - they have a permanent load connected. It's like the usb charger is plugged in all the time and can't be isolated for IR testing.
Reply to Socket outlets with built in USB in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hello all. I'm just looking for a bit of advice regarding our meter. EDF keep badgering us to have a smart meter fitted, and they recently...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
