Discuss Solar edge in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
OK - A few tips:
As soon as inverter arrives log on to Site Registration and register the inverter with the S/N as per instructions, this enables the online portal to be set up during install. do install and make a map of the peel off bar codes like the attached.
Also VERY important, make sure you wire the CAT5 as per instruction attached.
Then submit site plan to SE for them to physical map the installation to report in the portal.
  • IMG.pdf
  • se_application_wiring_ethernet_cables.pdf
Thanks for that!!!!!
ok - a few tips:
As soon as inverter arrives log on to site registration and register the inverter with the s/n as per instructions, this enables the online portal to be set up during install. Do install and make a map of the peel off bar codes like the attached.
Also very important, make sure you wire the cat5 as per instruction attached.
Then submit site plan to se for them to physical map the installation to report in the portal.
Piece of cake my man - infact i find it easier than normal strings - reason being - you can install all the modules and get all the string cables clipped up before panels go on, then simply plug each panel into each module, less faffing.
Ohh - depends on your mounting system, but i use Renusol and i buy extra "T" bolts and nuts to bolt the optimiser onto the rail.
Reply to Solar edge in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi Everyone, This is Yunus from ENF Solar. For over 18 years, we've been the go-to source for solar suppliers, manufacturers, wholesalers, and...
Hi wondering if you could help with some advice Been running an Essex/suffolk based electrical firm for last 20 years, mainly light commercial...
We're pleased to introduce Green2Go, the newest addition to the Electrical2Go family! This dedicated platform is the ultimate destination for our...
Hello everyone, I currently have two solar modules left over from an installation and I would like to use them to set up a solar system on the...
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
