- Feb 10, 2012
- 2,264
- 2,984
- 4,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- If other, please explain
- Running own small electrical company.
I don't do PV, so not overly familiar with specific regulations.
Yesterday I was changing a consumer unit, and the isolator for the PV was adjacent to the consumer unit.
Due to needing a bit more space, I had to move this isolator a few cm and noticed it was single pole, switching L only.
A second isolator at the PV end of the cable was the same type.
I was a bit surprised, I'd expected N would have been isolated as well, but it was not.
Is this common practice, or should double pole isolators have been used?
