Search the forum,
Discuss Solar system on outbuilding at home in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Davidp
I have a couple of outbuildings at home that would be really good for a system.
I only have single phase in the house and buildings.
They are 60 meters from the consumer unit in the house and I think the cable to the buildings is 6mm.
My question is (and I am trying to get some knowledge before talking to companies) if the panels were on the roof of the outbuildings and the inverter and generation meter where in the outbuildings then this would give a higher figure than if the if the generation meter was by the consumer unit.
My guess is that I would lose a bit of power up the cable to the buildings. I know that if I have the lights on in the winter and put a heater on the lights dim, so would the link cable be too small/long?
Not sure if I have made myself clear but I guess I am trying to cheat a bit with the loses.
Cheers
The cable to the outbuildings is far too small. The volt drop would be too much and you'd have no end of problems.
You're right to suggest that a generation meter at the inverter position will give better readings than a generation meter at the main consumer unit.
Reply to Solar system on outbuilding at home in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all I'm looking for some help on a query I have. I'm currently involved with a new build with the plan to fit Solar in the very near future...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
I have read all I can find about radio 4 and tele switching, but can't find if this changes when our clocks change. It all started when I decided...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
