Discuss solar thermal quote in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi Guys I am going to get solar thermal installed on my house. I know some members do multiple renewables so If you like to give me a quote then please contact me. the heating system is a regular with a big water tank in top floor directly under the north roof as it slopes down , I think the tank is dual coil already. I am based in Heywood lancs
you will need a GDA for the RHPP
can't imagine that would be a problem in this case given who the customer is and what the company they run does;)
could be interested, will drop you an email, only problem being how busy we are right now, but I am looking to do more solar water heating systems as we've only done 2 this year so far I think.
Reply to solar thermal quote in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi wondering if you could help with some advice Been running an Essex/suffolk based electrical firm for last 20 years, mainly light commercial...
Hi, I have a Solar Iboost and I understand that when I export electricity, it gets directed to the hot water tank. Is it supposed to be directly...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I get the feeling asking this will produce head shaking, I'll ask anyway... I have a hot water tank with a single immersion heater. Currently...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
