Discuss Spurs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Spudnik
Your thoughts gentlemen please.
Kitchen RFC.
Double socket, spur down to single socket for fridge.
Spur also from same double socket to SFCU for boiler.
So, in effect, 4 cables into back of double socket.
Any reason why not?
I thaught that only one spur per double socketwas allowed under the regs? Im assuming its on a ring main and that the room is not bigger than the area specified in the regs?
Not sure of numbers, not got books at home.
Although I am industrial, so im just going off what very little memory I have of the regs back at college many moons ago
so Jason if i get you right there is 4 x 2.5 at the socket terminals? Thought they may be getting a bit tight?
I would think about combining them into the ring if possible.
use this link, its from the red book, it shows rings and radials...what can and cant do
you may want to print this off if you have one of the first copies of the new regs to update them
www.------.org/publishing/wiring-regulations/updates/bs7671-2008-corrigendum-jul08.cfm?type=pdf
Good luck at getting all them 2.5mm in 1 connection:confused:
Kitchen RFC.
Any reason why not?
Can't you extend 1 of the legs and put both spurs on the ring.Shouldn't be a problem then:D
Sorry peeps, i let this one run without checking back.
Its existing at the moment.
Just to confirm, its a double socket on a kitchen RFC, which spurs to a boiler SFCU at 3A.
Then the fourth cable (from the same DS), drops down to a single socket behind a freestanding fridge.
Now as Mark said, although not ideal, i really cant see a problem, apart from being a little cramped in the back of the socket. It has a 35mm back box with standard white accessories.
Surely, from a loading point of view, its not a lot different than having two DS next to each other with a spur off of each socket?
I stand to be corrected...again.
Areb you not putting a switch spur in to control the fridge?, if so you could easily adjust to add the switched spur to the ring then spur off for the boiler
Nooooooooooooo.
Its a PIR im doing.
What i am describing is already there.
Edit: Just realised i posted in the wrong forum.:rolleyes:
Reply to Spurs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
