Discuss Staircase timer 4 wire and 3 wire in the UK Electrical Forum area at ElectriciansForums.net
hi everybody :) i have recently bought a staircase timer, and on the side of it there are 2 different wiring diagrams. one of it says 3 wire and the other says 4 wire. I have always connected them in the 3 wire diagram but i'd like to know what is the other one and for when it is useful. here is a photo of the timer.
looks to melikethe 4 wire method allows ar a manual switch local to the lights.
Reply to Staircase timer 4 wire and 3 wire in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Evening all, Have been asked to wire one of these into a heating system that has no separate control (or valves) for HW & CH. Customer is going...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
