I
ian
Hi Guys
First post on here for some time.
I was called to a fault earlier today which I cant get my head round. the lights in the house are flickering. Not all that unusual I hear you cry, however they are flickering when they are switched off, and at random times, often in the evening or very earl in the morning.
I have tested the installation and everything is ok, no neutral problems, polarity, Ze & Zs are fine. I have seen a similar problem previously and the cause was a pump nearby pumping station dumping a load of fault current, however I called united utilities and there is no pumping station for miles.
Hope someone can help.
Ian
By the way it’s a TNS-S system.
Ian
