Discuss sub mains help newbie in the The Welcome Forum area at ElectriciansForums.net
C
Cookiebadboy08
Hi guys please bear with me as I am new to the electrical game
I have done a private job and run a garage board to a shed with a six mm amoured fone all relevant test on the curcuits
And done a zs at db but do I have to r1 r2 the sub mains to put on the test results or is tbis not needed and do I need to do
Ir test on sub mains and put it down on the certificate or just the radial xuircuit and lighting
Cheers guys
Yeah I have done 1 test cert and filled in but first two curcuits are on test sheet is incoming rcd 40 amp mains 61008 rcd the 6 mm mains to this board do I have to r1 r2 this and write on test sheet
Cheers guys sorry I am all new to this need some advice
And yes will notify as I know it comes under part p
Yes you carry out all tests on the submain, it is a new circuit so you test it as such.
You record the results on the first test results sheet in your certificate.
You record the test results for the circuits on the sub-board on your second test results sheet.
Alternatively you could record them all on the same sheet as long as you make a clear distinction between them.
Reply to sub mains help newbie in the The Welcome Forum area at ElectriciansForums.net
Hello all I have recently installed a sub main in 4mm 3-core SWA, approx length 45 metres, to feed a small garden office. Final circuits in the...
Looking for some guidance here. I'm currently shadowing a guy and we're testing a new extension on a school. 3 phase TNCS supply from the original...
Afternoon all. Bear with me on this one... Despite having been involved in the electrical industry for many years, I'm only just about to embark...
Hi, this is my first post here. I have a 3 phase board with a 40amp circuit breaker supplying a single phase board to a small office. I...
My father In law is selling his property and had a EICR done recently requested by the buyers. I thought the report was not the best quality with...
