Discuss Table lamp wiring regulations in the Lighting Forum area at ElectriciansForums.net
I have recently restored an ancient anglepoise lamp which is not a product as far as I can tell from the well known anglepoise lamp company.
it is fitted with 2 core wiring which is in good condition. As the lamp is in good condition and the only item which I have replaced is a switched brass bulb holder, does the lamp comply with electrical regulations for UK?
Many thanks,
Reuben Walton
Reply to Table lamp wiring regulations in the Lighting Forum area at ElectriciansForums.net
Hello! I design and build lamps, which has been a simple task so far, but I've decided to dip my toe into the dubious world of 120v LED PCBs for...
  • Locked
Hi I've just purchased a metal framed ceiling light from AliExpress and I am concerned that it has no earth connection or double insulated...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi All, I'm designing my own table lamp but having issues with the wiring. The lamp consists of an E17 socket, a two position toggle and a two...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
