Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
third pic..... is that a laptop power supply just below the isolator arm?Recently had to do a bit of fault finding on a couple of machines, the panel's a bit of a mess
Like most of the equipment it's fed with SWA, even if it's on wheels!
Another panel, note the DIN mount PSU lying in bottom of enclosure
For the time it takes to make it look tidy why the hell do people leave things like this! I would be embarassed to leave an abomination like that
Meticulous labelling. Makes it so easy to find the circuit you need. (actually two are labelled (wrong way round), in felt-tip, bottom right)
There looks to be two more buried below it too or am i seeing things?SWA for outside lights 'buried' about two inches below the ground, and under a tarmac driveway, where at least it is sleeved in water pipe! And yes, that is the armouring you can see.
Seem that before, just the worst idea ever, "we will just bury it a bit". And under a driveway, very rare there is any ground movement there!SWA for outside lights 'buried' about two inches below the ground, and under a tarmac driveway, where at least it is sleeved in water pipe! And yes, that is the armouring you can see.
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
