Discuss Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
I had this issue, when we had our new cooker installed recently. Rated at 8.7kW, installing 'engineer' insisted it had to have a 45A 10mm supply, which it did ;). And he then did the final connection in 10mm 6242y.
I put it on my clamp meter the other week, to see what current it does draw (you can have two ovens & a grill on), which is when I found out my clamp meter was u/s. Still reckon it won't draw than no more than 14A
Ultimately if the flex by the nature of the load can’t be overloaded I don’t see the problem regarding overload protection only fault protection needs to be assured.
Went to do a report on a kitchen install this morning and it was bad from start to finish, badly fitted units, not installed to the plan, badly tiled floor etc
on the electrics the electrician apparently dose not carry a spirit level
but the thing that worries me is the 16 amp oven wired into a 40amp switch straight back to a 32amp mcb won't the oven flex be rated to 16amps there for a fire risk when its on a 32amp mcb under fault?
Can you please post some pictures of the Terrible install? apart from a couple of switches being un level I am struggling to see terrible, a little heath robinson yes, but terrible?
No other pictures I am afraid, but if I tell you that the integrated fridge was fitted in such a way that it could be pulled out on top of you with very little effort, the appliance housing is out of level, the side panel has also been pushed inwards by 5mm meaning the doors can not be level, cornice & plinth cut to short, original sink binned and a smaller sink installed because installed the sink unit to close to the wall, wall units installed with out the fillers so the doors are rubbing against the walls, I could carry on but I think you get the idea, if it was my kitchen I would have it re-installed correctly but the customer has had enough and just wants a solution to the main issues.
mike.notonly are the sockets/switches notlevel,but the 3.5mm fixing screws don't have their slots aligned.that is terrible.
Next time get the photos put up. We can only imagine how bad it was. Until then we will take your word for it
Reply to Terrible kitchen install in the UK Electrical Forum area at ElectriciansForums.net
I have a double oven connection unit. Fed with 4mm cable,40 amp MCB. Hob connected to it with 4mm cable. Bought new oven,stated 16 amp but with...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi, I've searched these forums and have found quite a bit of good information, but not specifically to my query. My house is about 9 years old...
