Discuss Thermostat controller in the UK Electrical Forum area at ElectriciansForums.net
Bob1955
I want to replace my old Thermostat controller with a new one the old one has 2 wires neutral and live the new box is volt free I was told it will work I just have to put live wire to live switch and not use neutral is that true
i doubt the old one has just a live and neutral
A room stat is a switch so it must switch a signal to turn on the boiler etc
I would think you you have just a live in and a switched live back.
If the new stat you have is battery operated it most likely will work with what you have but if you are in any doubt please just get a professional in to replace
as above ^^^^^. check your new stat. instructions. if it needs a neutral you may find it's incompatible with the wiring that you have .
Yes it is battery operated and I was quoted £170 for someone to sort it for me is that a fair price
Hi - I’d try to get another quote as it should be a simple job. Many folks would fit and test it for you for a call out fee, way less than that £.
According to the instructions no neutral is required. Can you show a pic of your old stat connections.
That's the old one
[automerge]1571435303[/automerge]
The left is neutral right live middle empty
As previously stated you have a line in and switched line out, ignore the fact it is blue it should be sleeved brown. You should be able to just connect those to the two terminals on your new stat, doesn't really matter which way around. To be honest the fact it is wired in flex indicates a bit of an ad hoc installation but nevertheless it should function. TURN THE POWER OFF FIRST :)
So just connect one to mains Live and one to switch live is that right
[automerge]1571438047[/automerge]
I would like to Thank everyone who help me on here a big Thank you
Reply to Thermostat controller in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi everyone just looking for some advice before buying stuff not planning on carrying out this work myself will get someone who knows what their...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
