Discuss Three light switches on one plate in the DIY Electrical Advice area at ElectriciansForums.net
TheJay
Hello there, just had a triple light switch fitted but the order of the switches is wrong. The left and centre switches need to be swapped. Can someone please tell me how do I do this?
Picture:
Looking at the plasterwork around the switch I'd guess the electrician might still be around. Can't you get him to do it?
With multiple light switches there's always a possibility there could be live supplies going to different switches which are from different circuits at the CU. There could be more than one circuit that needs isolating before you start messing so beware.
I'll echo this advice
As above if you have just had this done get him back and let him sort it for you.
Reply to Three light switches on one plate in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi all, after a bit of advise if ok please. We have a switch which currently only powers one single LED down light in our ceiling. From this...
