Discuss Three way light switch does not work correctly in the DIY Electrical Advice area at ElectriciansForums.net
stew24
Hello,
A few years ago I had my house rewired before putting up new drywall. I had a three way installed to control the lights in our mudroom, one at the exterior door and one in the kitchen. This is currently not working correctly and I am trying to understand why.
The wall box at the exterior door contains the three way switch for mudroom lighting, a three way switch for garage light, and a single switch for a light directly outside the door. The wall box in the kitchen contains the other three way switch for the mudroom, a three way switch for the kitchen itself and a single switch for the kitchen. When drywall went up and the electrician connected everything the mudroom lights worked from both switches, but my exterior light had no power to it. I had the electrician come back and he took power from somewhere in the box next to the exterior door to get the exterior light working, but now the mudroom light switch does not work here and is only useable from the kitchen. I also have a white and black wire coming into the box at the exterior door that test positive for continuity but are not connected to anything within the box.
I have reached out to the electrician who did the work but have not received a response. Any advice on what may be the problem would be appreciated and thank you.
Hello,
I don’t think you should have paid him. If it was all working before your so called electrician came in, then it should be working when he left. You can always turn him into the NY board of examiners of electrical contractors or does he even have a license. Good luck
Reply to Three way light switch does not work correctly in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
I replaced a single pole to exterior lights with a smart switch. Next to it is a 3way to my foyer light. The foyer and the smart switch to...
Hello - Looking for assistance regarding a problem with my three way switch what was working over the past four months with no problems until this...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
