- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Retired Electrician
Went to look at a job yesterday, shower room refurbishment. I'm just replacing the existing main light, vanity mirror and dual fuel towel rad. No RCD protection on lighting, but as I'm just replacing what's there, I consider that just maintenance.
There is also an extractor fan, located outside just outside zone 2 (appears suitable for outside zones). Unusually, the TP isolator (plate switch) is located next to fan (I normally install isolator outside bathroom). I'm only removing fan & isolator, so the wall can be tiled, then re-fix. I've checked OSG, and plate switches can be installed in bathrooms outside zones, but still not 100% happy. Thoughts?
