Discuss Trying to add a light fixture to a box that used to have a ceiling fan in the DIY Electrical Advice area at ElectriciansForums.net
Here is a picture of the ceiling box
In the kitchen we have recessed spotlights and there used to be a ceiling fan, and there is only 1 switch with a dimmer. We removed the fan and wanted to add a Bazz disk to sort of fit in with the spots. I opened it up, connected it in every possible combination and nothing works. Here is a summary of what I figured out:
- The black from OLD and NEW have to be connected together or the spots won't work at all
- I connected the 3 whites and 3 grounds together and never touched them. Assuming that's correct
- I tried every combination with the 3 black wires (OLD group, NEW group and light ficture) and red wire, nothing worked.
- If I connect the light fixture to NEW black, it is always on regardless of what else is connected there
- If I don't connect it to to NEW black, no matter the combo, it won't turn on at all
I tested the wires with a contactless wire tester:
- NEW black and NEW red seem to be always live even when the switch is off.
- OLD black seems to be live when the switch is on, but its unclear. The tester beeps a few times and stops. If I move it a bit it'll do the same. Worth noting I think the wire is aluminium (old house)
- When I pass the tester over one of the spot, it beeps whether the spot (and switch) is on or not.
- White and ground have no readings
I am completely stumped. No idea what to do or what is going on... I re-wired it OLD with NEW black and took off the fixture for now. The spots work right now.
Ask any question if it can help!
TL;DR
7 wires in a ceiling fixture that used to house a fan, 2 are always live. Can't figure out how to link a light to to the switch with those wires.
Reply to Trying to add a light fixture to a box that used to have a ceiling fan in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
