Discuss Trying to match Socket outlet. in the UK Electrical Forum area at ElectriciansForums.net
Lou7
I need to add another couple of sockets to an existing job, trying to match these sockets.
Reply to Trying to match Socket outlet. in the UK Electrical Forum area at ElectriciansForums.net
Hi, after some discussion with electricians, does removing a 16A or 32A socket constitute safe isolation? I understand that removing the socket...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hi I’m getting a new kitchen fitted, there’s a existing socket outlet fitted into a pipe chase, for the rewiring of new socket outlets is it...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
