C
Colinmc1
Is it sufficient to just use a decent terminal cover on an earth rod or must it be protected by a proper inspection box?
Discuss TT earth rod question in the UK Electrical Forum area at ElectriciansForums.net
yep...just dyin to get knocked off the top of the rod...lol...Always use a flush to ground earth pit box, either made for purpose, or as Marvo suggests a valve pit box. Just never use one of those small black plastic earth rod boxes They are next to useless, and won't last anytime at all, in areas of pedestrian or car traffic.
You can get some wee sized pits if size is a problem?
Hey don't knock the plastic boxes - they're fine in a back garden close to the house wall. 'Horses for courses' and all that stuff! I've never had to install one in a pedestrian walkway or where there's car traffic and I've fitted a fair few.:coolgleamA:
Pete
Well, there you go then, You shouldn't be driving earth rods close to the house walls to kick off with, that's where all the building rubble is going to be!! Your driving a rod into a non-existent soil, as it'll be made-up of all manner of crap below ground!! Those plastic boxes are totally useless, and as far as i know, fit for only those short thin 3/8'' non-extendable excuse for an earth rod. Which tells me a lot about those fair few electrodes you've fitted, save to say, none of those fitted rods will be providing any form of stability!!
Excuse me! No need to be so nasty! Do you always talk such crap? It's replies like yours that bring this forum into disrepute!
The plastic boxes are open at the base and will take any size rod you care to fit.
I agree with you about 3/8" (usually plated steel) rods. I don't use em. I only install 5/8" extendable ones.
How close is close? Don't be so literal! How would you know what I'm driving into? Did I say? N0! Clay fyi.
Around here - a country area, hundreds of properties have earth rods, and they are all within 300mm of brick walls. They've been there for 10s of years and every one that I've tested has been good. Maybe they are into rubbish but they're certainly stable.
Pete
Reply to TT earth rod question in the UK Electrical Forum area at ElectriciansForums.net
