Search the forum,
Discuss tv aerial in the Electricians' Talk area at ElectriciansForums.net
Hi
Its not something i do but got asked to look at some tv points what arent working.
Ariel in loft then goes to 3 tv sockets not far away about 25m run loop in out method but only 1st tv is working all cables look fine well parts i can see are anyway.
Does it need a booster so other 2 tvs work
If i was wiring it i would of took all 3 tvs back to ariel to a booster but was already done.
Any help
Cheers
Re: tv arielw
Hi,
Two things to try,
1) Try disconnecting both cables connected to 1st TV and plug cables through directly to 2nd TV and see if it gets a signal then.
2) Connect the core and earth of the cable from 1st TV to 2nd TV, then at the 2nd TV end of cable, confirm continuity of the cable between 1st and 2nd TV.
Reply to tv aerial in the Electricians' Talk area at ElectriciansForums.net
I have a known working TV and went to set it up in another building for an old chap. He has about 3 TV's already. I connected the TV to 2 seperate...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
Hi All, I am having fibre to the premises fitted tomorrow, much earlier than expected, supposed to be another month or so. I looking for some...
