Discuss TV On Chimney Breast in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
wallyanker
Hi folks,
Have a customer that wants me to put a socket half way up the chimnet breast in their lounge so that they can mount the tv on the wall and see no wires. I have advised them against this as they have a working gas fire and the chimney gets quite hot but they want it doing anyway.
Their is a socket and aerial point to the left of the chimney so was going to spur from this but my question is, how do I get the wire to the socket on the front of the chimney without going through the chimney due to the heat. I am also not allowed to lift any laminate flooring as they do not want it damaging.
Any help appreciated.
dont do what a spark in the company i worked for last did and drill a hole through the chimney , what you could do is get a piece of ceiling trunking looks like coving and put this round the top of the chimney breast ,run up the ressesed corner into the trunking and then drop down from above wouldnt reccomend a chase you can get some quite attractive oval trunking to drop down
Just to ask the question.
Do you think it is ok to chase into the chimney breast or advise against it?
only from skirting board up the height of a 1 gang box just for a socket?
I used this on my upstairs chimney breast but as you will have the fire at the bottom and don't have access to the top i can't see it being any use to you. But i would advise against chasing a chimney breast.
Does anyone else think mounting a tv above a gas fire is asking for trouble?
You're not even supposed to put mirrors above open fires, never mind expensive electronic equipment.
thought it was only children you should mount above the fire
A socket above the fire is asking for trouble, but a TV even more so. I know in the current climate you probably need all the work you can get but in this case, if the customer will not listen to reason, my advice is walk away.
not got a socket above it though, and the temp of the tv runs at the same temp as the same one in the bedroom that`s on the wall
if we are to believe the scaremongers on so called global warming we won't need gas fires anymore, problem solved
Ive chased a chimney breast and had no problems, they are made out of the same brick as everything else, and the house wont fall down. I spurred from upstairs ring and came down the chimney breast to single socket and aerial point
Have mine on wall but luckily its dot and dab so managed to fish scart thru walls. did get told by TV eng friend of mine though that I should not use gas fire as it will severley reduce life of TV!!!!...luckily we never use the gas fire anyway.
Reply to TV On Chimney Breast in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Good afternoon, Sorry for the long post but can find answers to my questions anywhere. I’m want to replace my old cooker hood for a new one...
Have a contractor trying to run a new electric line to a 'picture light' over the fireplace mantle. As you can see in the photos, the entire...
Is it possible to install a double socket on a chimney breast that has an active wood burner at the bottom? Looking to mount a TV above the...
I have a known working TV and went to set it up in another building for an old chap. He has about 3 TV's already. I connected the TV to 2 seperate...
